Hi Team, how can I get jira project boards with column names and status names in these columns using Adaptavist Scriptrunner for Jira Data Center
@Stefan Stadler you inspired me to develop this code:
import com.atlassian.greenhopper.model.rapid.Column
import com.atlassian.greenhopper.service.rapid.view.RapidViewService
import com.atlassian.greenhopper.service.rapid.view.ColumnService
import com.atlassian.jira.issue.status.Status
import com.onresolve.scriptrunner.runner.customisers.JiraAgileBean
import com.onresolve.scriptrunner.runner.customisers.WithPlugin
@WithPlugin("com.pyxis.greenhopper.jira")
@JiraAgileBean
RapidViewService rapidViewService
@JiraAgileBean
ColumnService columnService
def applicationUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
// Your real board IDs here:
def targetBoardIds = [1L, 2L]
def htmlBuilder = new StringBuilder()
htmlBuilder << "<table border='1' cellspacing='0' cellpadding='5' style='border-collapse: collapse;'>"
htmlBuilder << "<thead><tr>"
htmlBuilder << "<th>Board Name</th><th>Board ID</th><th>Column Name</th><th>Status Name</th>"
htmlBuilder << "</tr></thead><tbody>"
if (rapidViewService) {
def rapidViews = rapidViewService.getRapidViews(applicationUser).value
rapidViews
.findAll { it.id in targetBoardIds }
.each { rapidView ->
def columnsByStatus = columnService.getColumnsByStatus(rapidView)
def columnStatusMap = [:]
columnsByStatus.each { Status status, Column column ->
columnStatusMap[column.name] = columnStatusMap.get(column.name, []) + status.name
columnStatusMap.each { columnName, statusNames ->
statusNames.eachWithIndex { statusName, idx ->
htmlBuilder << "<tr>"
if (idx == 0) {
htmlBuilder << "<td rowspan='${statusNames.size()}'>${rapidView.name}</td>"
htmlBuilder << "<td rowspan='${statusNames.size()}'>${rapidView.id}</td>"
htmlBuilder << "<td rowspan='${statusNames.size()}'>${columnName}</td>"
htmlBuilder << "<td>${statusName}</td>"
htmlBuilder << "</tr>"
htmlBuilder << "</tbody></table>"
// Return the HTML result
return htmlBuilder.toString()
actually, there is some code to access the boards using ScriptRunner.
the following code can iterate over all boards and print out the mapping for each Status and also lists a mapping for the respective columns. This can be modified of course to what exactly is needed by your usecase:
@JiraAgileBean
@JiraAgileBean
def applicationUserInput = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
if(rapidViewService) {
def rapidViews = rapidViewService.getRapidViews(applicationUserInput).value
rapidViews.each{
Map<Status, Column> columns = columnService.getColumnsByStatus(it)
columns.each{Status status, Column column ->
log.warn("Status name: ${status.name}")
log.warn(" Column name: ${column.name}")
log.warn(" Complete list of status IDs: ${column.statusIds.join(", ")}")
log.warn("__________________")
Hello @Chamdarig Dall
Big question for me here is: why use Scriptrunner as building the board you desire can be done in Jira right out of the box?
Dick
I don't need it for building. I need it to get data about boards for reporting
A board is just a pair of glasses to look at the current status of a (part of a) project or projects. There's data in the work items.
When you're talking about reporting, you implicitly are interested in what has been done in past sprints. For this, Jira has the reporting section, where you can visualize metrics over past sprints. This section is full of handy charts and calculations, those of which you cannot obtain from boards in an easy manner. So why not start using sprints (or when you're more Kanban oriented, start using releases) and use the reporting section?
Dick
Nope, I mean exactly what I wrote, "Get jira project boards with column names and status names in these columns"
I can get it via the REST API:
/rest/agile/1.0/board/{boardId}/configuration
But I was curious if I could get it with Scriptrunner
