I know how to get remotelink for a single Jira issue (/rest/api/2/issue/key#/remotelink), but I need to return remotelinks for all issues in a project. Im pulling from Power BI and cannot readily loop through a bunch of issues and send REST calls for each.
I tried all the expansions under an issue search( /rest/api/2/search?jql=....) . I can see info in changelog, but that is a pain to parse, plus it doesnt have all the info on the remotlink like status.
Is there a way to get the remotelink info for a batch of issues?
My remotelinks are to Zephyr.
Thanks a lot
Thanks for leaving your comment on the Atlassian portal, but please see our link below to have direct correspondence with Team Zephyr's support staff. They will be able to answer any technical questions you may have.
https://www.getzephyr.com/support (submit a ticket)
Thank you and hope this helps,
Team Zephyr
