Getting error "Comment body can not be empty!" when trying to add a comment by REST API
Adam Rypel _MoroSystems_
As described in the summary - I am using ScriptRunner. Here is the code I am trying to run:
 def commentBody = [
"type": "doc",
"version": 1,
"content": [
"type": "paragraph",
"content": [
"type": "text",
"text": "The group could not be created. Response:"
post("/rest/api/3/issue/GS-1/comment")
.basicAuth(SERVICE_USER, SERVICE_API_TOKEN)
.header("Accept", "application/json")
.header("Content-Type", "application/json")
.body(commentBody)
.asJson()
 Here is the response:
POST request to /rest/api/3/issue/GS-1/comment returned an error code: status: 400 - Bad Request
body: {"errorMessages":[],"errors":{"comment":"Comment body can not be empty!"}}
I followed ADF documentation here: https://developer.atlassian.com/cloud/jira/platform/apis/document/structure/
Any idea where the problem could be?
Thanks!
2 accepted
Martin Bayer [MoroSystems, s.r.o.]
Hi @Adam Rypel _MoroSystems_ , the correct format of the request is:
 def commentBody = [ body: [
type: "doc",
version: 1,
content: [
type: "paragraph",
content: [
text: "Lorem ipsum dolor sit amet, consectetur adipiscing elit. Pellentesque eget venenatis elit. Duis eu justo eget augue iaculis fermentum. Sed semper quam laoreet nisi egestas at posuere augue semper.",
type: "text"
Thanks! This one works as intended
Tim Perrault
February 3, 2022
The errors is saying it's missing the body part to the actual api post. Could you try updating your code and see if this helps.
def commentBody = {"body":
"type": "doc",
"version": 1,
"content": [
"content": [
"type": "text",
Tim
Thanks! Body was indeed the problem, just had to adjust syntax as Martin said:
type: "doc",
version: 1,
content: [
type: "paragraph",
content: [
type: "text"
Like Tim Perrault likes this
FREE
