How do I access the Work Management template? Is there a comprehensive tutorial for learning to use this product?
Hi Allison,
The best way is to get a free instance and play with it.
Also you can find info here:
https://community.atlassian.com/t5/Jira-articles/Understanding-Jira-Work-Management/ba-p/1881521
Hey @Allison James and welcome to the Atlassian Community (and Jira Work Management)!
I'd recommend a good first stop is Atlassian's YouTube channel, where you'll find videos on:
You should also check out the Atlassian University's Getting Started With Jira Work Management course:
https://university.atlassian.com/student/path/1554210-getting-started-with-jira-work-management
To access project templates go into Jira, select "Projects" then click "Create Project" in the dropdown menu. You'll then see a range of templates under Work Management. Pick the one that best suits your project/type of work.
Hope that helps!
