Git Integration for Jira vs Azure DevOps for Jira
Matteo Morato
March 26, 2025
Hi everyone,
we are currently using Git Integration for Jira plugin (https://marketplace.atlassian.com/apps/4984/git-integration-for-jira-azure-devops-github-gitlab?hosting=cloud&tab=overview) to connect our Jira cloud environment to Azure DevOps repository but i recently noticed an Atlassian App called Azure DevOps for Jira (https://marketplace.atlassian.com/apps/1232793/azure-devops-for-jira-official?hosting=cloud&tab=overview).
At the moment we just use the plugin to reference Jira issues to activities performed in Azure DevOps but we would like a more seamless integration where you can either:
- pilot Azure DevOps activities directlly from Jira (i.e. merge/push happens when a Jira transition is triggered)
- limit Azure DevOps activities based on Jira issue status (i.e. developer perform a merge request but this can go on only if the Jira issue is in a certain status).
Any idea about this? Did you try these two plugin and have any opinion about them? Which one is better?
Many thanks in advance!!
Matteo
Move Work Forward
Hi @Matteo Morato ,
Thanks for asking.
There is an official app and one from Move Work Forward. See the search here.
None of the applications support what you want.
I am from Move Work Forward and we are ready to work with you to enhance our app to support your needs.
Let's have a call where we can discuss your use cases and the current setup (schedule here).
Look forward to working with you.
Leo
Syed Majid Hassan -Exalate-
April 22, 2025
Hi Matteo,
A very warm welcome to the community!
This should certainly be possible and you might actually be able to bring more value to your automated workflows by using a deep integration solution like Exalate. Anything and everything contained within your Azure workItems can be synced and automated status/ priority changes on the remote end can be performed based on specific conditions on the workItem.
Please let me know if you have any questions.
Majid (Exalate team)
