×Hi, I installed Github for jira, but not found any my repo on my project.
please suggest me,
Thank you.
Hi @Patchara ,
as far as your github instance is connected correctly within your Jira you are able to link issues with using the issue key within branch name and/or commit messages. You will then also see repos that issues were linked to in your info page.
What exactly are you trying to do in your last screenshot? Could you explain your use case and which result you‘d expect?
Best
Stefan
