×Hello,
I am quite a novice user of Jira, and have been confronted with the following situation described below. There are two companies, company A and company B. Company A makes a product for company B. Company B uses the product, and puts their error descriptions / problem reports into their Jira system as tickets. Company A receives the error description and set a ticket in company A's Jira system. What the two companies would like to have is an automatic linkage between the two Jira systems:
Is this linking with automatic updates possible?
Thanks for your support!
Hey @Istvan Fay
I gave a talk last year about cross-company collaboration scenarios in Jira last year. It mentions 5 ways how you can collaborate:
Here's the full talk:
Let me know if you need further help.
Matthias.
PS: I'm part of a team behind the Backbone Issue Sync - one of these issue sync apps.
Hi Matthias,
thanks, that was a avery good presentation, help to put some issue on their places!
BR, Istvan
Hello @Istvan Fay
Welcome to the Atlassian community!
For Company A and Company B:
- What is the hosting type for their Jira instances? Are they self-hosted (Jira Server/Data Center) or Jira Cloud hosted?
- In what type of project are the tickets being created for each company? Are the tickets in Jira Software projects or Jira Service projects or Jira Core/Work Management projects?
Hello Trudy,
thanks for the fast response!
From the attended usage point of view, I would say it is Jira Service Management: we would like to use it as an error ticketing system
The cooperation as described in Wikipedia under Networked Help Desk API (Networked Help Desk - Wikiwand) is pretty much the way how we would like to cooperate.
Is the understanding correct that Networked Help Desk API is already built in into Jira, so when we have separate Jiras, but turn the API in both sides on, this automatic exchange of update is solved?
I have not seen that Networked Help Desk information before.
All my previous experience and understanding of the working of the Jira products is that the synchronization of issues between two separately hosted Jira products requires the use of an app to configure and manage that synchronization. There are a variety of apps for that purpose available in the Atlassian Marketplace. You can find this topic discussed in multiple locations by searching the internet with Google (link to example search).
Included in those results is the third party app that comes up first when searching the Atlassian Marketplace - Issue Synch - Synchronization for Jira. I have not used that app before so cannot provide any first hand experience or recommendation about it.
Hi there!
I'm part of the team responsible for the mentioned app - Issue Sync for Jira.
This plugin enables synchronization of two separate Jira's which means that you can automatically create a ticket in Company's A Jira while Company B reports an error in their system. All the data (fields, comments, attachments, statuses) can be then copied over to the remote ticket as specified in the configuration and kept in sync also when values change.
It eliminates manual work while remaining secure - the app lets you decide which projects/ issue types and fields will be exposed to your sync partner. Even the admins of both Jiras won't see anything more than configured.
Recently we published also a lighter, more user-friendly version of this plugin - Issue Sync Lite. It will also serve this case and... it's free :) If you would like to see it in action, we will be happy to arrange a demo for you.
Best regards,
Kasia from Deviniti
Dear Kasia,
thank you very much, that answers my question perfectly! At the moment we are planing the setups, so the question is at the moment only theoretical.
Thanks also Trudy for the support!
Dear Kasia,
an issue that came up recently: you have written "and kept in sync also when values change". When one side changes a value, how long does it take until the update appears on the other side: seconds, minutes, hours? There were very differing guesses in the project about the duration :)
BR, Istvan
Hi @Istvan Fay
My apologies. I must have overlooked your question!
Usually - seconds, however, it also depends on the type of synchronized elements - for example adding or removing attachments might take even a few minutes due to their size and Jira limitations. But it's never a matter of hours!
Hope that helps :)
Kasia
Hi @Istvan Fay
This is Majid @ Exalate.
As has been pointed out, issue synchronization apps such as Exalate, specialize in performing this Jira to Jira collaboration between two independent instances. In our experience, the most important factors to consider in such cases are security, granular control over data and autonomy of both sides. You can read up about how Exalate excels in cross-company collaboration but keep these factors as the driving force behind our solution.
Hope it helps.
Happy syncing!
Majid
