If I create a Global automation on Jira for all projects, that means every project I create or every project anyone creates?
Hi! Every project anyone create ;)
Be in mind the limit of executions when the automation is Global.
Hi @Rafaela Gomes Azevedo , welcome to the Atlassian Community!
Global automation applies for all projects that anyone creates.
You can select the scope of the automation rule during creation under rule details, see below:
General best practice is to limit the scope to the project the automation applies to in order to keep execution within limit.
Have a look at: https://support.atlassian.com/cloud-automation/docs/jira-cloud-automation/
Hope this helps!
Kind Regards,
Ash
