GreenHopper did not work after installing it?
Ahmed Helal April 17, 2013
GreenHopper is currently unavailable. This might be because an upgrade task has failed to run or has not not yet completed.
Please contact your system administrator if you continue to see this message.
this the eror that appear
Ahmed Helal April 30, 2013
It's system locale to 'English',it cuased by the imcopitical with Arabic system locale.
http://windows.microsoft.com/en-my/windows-vista/change-the-system-locale
Nic Brough -Adaptavist-
April 21, 2013
This question is now a duplicate of https://answers.atlassian.com/questions/160567/greenhoper-did-not-work-after-fresh-installation where there's a lot more information to work with.
Ahmed Helal April 21, 2013
this is my dbconfig.xml [where is the miss-config]
<?xml version="1.0" encoding="UTF-8"?>
<jira-database-config>
<name>defaultDS</name>
<delegator-name>default</delegator-name>
<database-type>mysql</database-type>
<jdbc-datasource>
<url>jdbc:mysql://127.0.0.1:3307/jira?useUnicode=true&amp;characterEncoding=UTF8&amp;sessionVariables=storage_engine=InnoDB</url>
<driver-class>com.mysql.jdbc.Driver</driver-class>
<username>root</username>
<password>123456789</password>
<pool-min-size>20</pool-min-size>
<pool-max-size>20</pool-max-size>
<pool-max-wait>30000</pool-max-wait>
<validation-query>select 1</validation-query>
<min-evictable-idle-time-millis>60000</min-evictable-idle-time-millis>
<time-between-eviction-runs-millis>300000</time-between-eviction-runs-millis>
<pool-max-idle>20</pool-max-idle>
<pool-remove-abandoned>true</pool-remove-abandoned>
<pool-remove-abandoned-timeout>300</pool-remove-abandoned-timeout>
<pool-test-while-idle>true</pool-test-while-idle>
<validation-query-timeout>3</validation-query-timeout>
</jdbc-datasource>
</jira-database-config>
Ahmed Helal April 20, 2013
it not work
it not work
April 20, 2013
That is not a useful posting.
What does not work? What have you done? What does the log say? Could you explain what you've tried and what the results were? (e.g. by following up the other threads here?)
Theinvisibleman
April 17, 2013
Is it a fresh installation of GreenHopper? Was there any problems during the installation of the plugin (any visible errors, etc). Nic has a point, the logs should point out what's wrong.
Theinvisibleman
April 17, 2013
Though, if the situation (and/or the logs) get a bit too complicated, you might want to consider raising this at out support site :)
thanks, yesit is fresh one
April 17, 2013
Read the log file from when you installed it - that should tell you what it's doing.
You might also want to re-index Jira, but I'd check the log first, and possibly try re-installing the plugin, followed by a restart of Jira
thank you ,on it
re-index not work
when try to enter "blugin data storage"
System Error
Cause:
Handler processing failed; nested exception is java.lang.NoClassDefFoundError: Could not initialize class net.java.ao.schema.ddl.SchemaReader
Referer URL: http://localhost:8080/secure/admin/IndexAdmin.jspa
April 17, 2013
Ok, re-index was worth a try.
What do you mean "enter plugin data storage"? The UI part of that is nothing to do with Greenhopper
