Greenhopper 6.1.2 Remove an issue from sprint in Work Mode give error.
Ubisoft
January 24, 2013
In greenhopper 6.1.2,
In the current sprint in the work board, if we select a Story and select remove from sprint option, the action fail and gives an error :
Workflow:
login
Click Agile and select Board
Verify we are in work mode
Select a Story
Go on the story panel on the right side and click on the gear icon
Select Remove from Sprint
Error message and issue still there.
Workflow for workaround:
Go in plan mode, and remove from sprint.
Or go in plan mode. Click on the issue id so it load in the panel on the right side
go back in Work mode
Click the issue, gear, remove from sprint
Works
jira is on 5.1.8
GH 6.1.2
Regards
Thiago Ribeiro
February 20, 2013
As I have previously mentioned the Bug for this problem is now public:
https://jira.atlassian.com/browse/GHS-7124
Please add yourself as watcher to receive further updates about the bug.
Br,
Thiago Ribeiro
Atlassian Support
Thiago Ribeiro
February 5, 2013
Currently this is a new Bug that we are tracking internally. I am checking if we can make this Bug public so you can add yourself as watcher and follow up the case.
So far all we have is the workaround mentioned by you which is not good at all but can keep your Board usage until we have a fix.
Tribeiro
AhmadDanial
February 3, 2013
Hey there.
This is indeed an interesting issue. Have you tried to contact the Atlassian Support to see whether they might have an idea on what could be the reason behind the error that you are getting?
https://support.atlassian.com/
If they are able to reproduce it on a fresh instance, who knows that it might be a bug.
Warm regards,
Danial
