I recently upgraded from 5.0 to 5.2 and am using JDK 1.7. I cannot get Greenhopper 6.0.7 to load and run. It looks like its complaining about neededing something on JDK 1.6. I have this running successful in my test environment, but not in my production environment. I cant find anything that is different. I have cleared all the tmp, work and cached plugin directories and am still encountering this issue.
2012-12-04 16:13:52,877 FelixDispatchQueue ERROR [osgi.container.felix.FelixOsgiContainerManager] Framework error in bundle com.pyxis.greenhopper.jira
org.osgi.framework.BundleException: Unresolved constraint in bundle com.pyxis.greenhopper.jira [116]: Unable to resolve 116.0: missing requirement [116.0] package; (&(package=javax.xml.parsers)(version>=0.0.0.1_006_JavaSE)(version<=0.0.0.1_006_JavaSE))
at org.apache.felix.framework.Felix.resolveBundle(Felix.java:3409)
at org.apache.felix.framework.Felix.loadBundleClass(Felix.java:1584)
at org.apache.felix.framework.BundleImpl.loadClass(BundleImpl.java:887)
at com.atlassian.plugin.osgi.util.BundleClassLoaderAccessor$BundleClassLoader.findClass(BundleClassLoaderAccessor.java:75)
at java.lang.ClassLoader.loadClass(ClassLoader.java:423)
at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
at com.atlassian.jira.plugin.DefaultComponentClassManager.constructEvenIfNotEnabled(DefaultComponentClassManager.java:133)
at com.atlassian.jira.plugin.DefaultComponentClassManager.newInstance(DefaultComponentClassManager.java:70)
at com.atlassian.jira.event.ListenerFactory.getListener(ListenerFactory.java:31)
at com.atlassian.jira.event.DefaultListenerManager$Listeners.loadListeners(DefaultListenerManager.java:162)
at com.atlassian.jira.event.DefaultListenerManager$Listeners.create(DefaultListenerManager.java:104)
at com.atlassian.jira.event.DefaultListenerManager$Listeners.create(DefaultListenerManager.java:99)
at com.atlassian.util.concurrent.ResettableLazyReference$InternalReference.create(ResettableLazyReference.java:143)
at com.atlassian.util.concurrent.LazyReference$Sync.run(LazyReference.java:326)
at com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:146)
at com.atlassian.util.concurrent.LazyReference.get(LazyReference.java:115)
at com.atlassian.util.concurrent.ResettableLazyReference.get(ResettableLazyReference.java:89)
at com.atlassian.jira.event.DefaultListenerManager$Listeners.start(DefaultListenerManager.java:126)
at com.atlassian.jira.event.DefaultListenerManager.start(DefaultListenerManager.java:47)
at com.atlassian.jira.ComponentManager.runStartable(ComponentManager.java:282)
at com.atlassian.jira.ComponentManager.startJIRA(ComponentManager.java:246)
at com.atlassian.jira.ComponentManager.quickStart(ComponentManager.java:212)
at com.atlassian.jira.ComponentManager.start(ComponentManager.java:197)
at com.atlassian.jira.upgrade.PluginSystemLauncher.start(PluginSystemLauncher.java:23)
at com.atlassian.jira.startup.DefaultJiraLauncher$3.run(DefaultJiraLauncher.java:105)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:284)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:169)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:98)
at com.atlassian.jira.startup.DefaultJiraLauncher.access$100(DefaultJiraLauncher.java:25)
at com.atlassian.jira.startup.DefaultJiraLauncher$1.run(DefaultJiraLauncher.java:64)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:33)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:59)
at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:80)
at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:75)
at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.get(MultiTenantComponentMapImpl.java:121)
at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.onTenantStart(MultiTenantComponentMapImpl.java:165)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:134)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:131)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.runForEachListener(DefaultMultiTenantManager.java:256)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startTenant(DefaultMultiTenantManager.java:130)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startAll(DefaultMultiTenantManager.java:203)
at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:108) <+5> (StandardContext.java:4791) (StandardContext.java:5285) (LifecycleBase.java:150) (ContainerBase.java:1559) (ContainerBase.java:1549)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
GreenHopper 6.0.7 is simply not compatible with JDK 1.7. Please upgrade to GreenHopper 6.0.8 immediately.
