I added custom fields and they are visible if issue if open in JIRA, but they are not shown in the Greenhopper issue view.
Could you please tell how to set these custom fields to be seen in Greenhopper?
Thank you.
Regards, Georgiy
You cannot customize detail view yet. Vote for this request: https://jira.atlassian.com/browse/GHS-3474 You may also want to read Atlassian's response to a related story: https://jira.atlassian.com/browse/GHS-4822
Hi
go to administration --> plugins --> greenhopper --> project template
choose the template
add them on the card view and summary view
cheers
hi
did you apply it on the same project template used in the jira project
check the project template (tools --> configure --> select the template that has the new modification
cheers
I did as you described (added my custom fields to the "card view") but it seems it does not affect anything on Rapid board. Do you know whether there settings apply to rapid boards?
Cheers, Georgiy
