Greenhopper project templates using Jira On Demand
Kasper Elbo November 27, 2011
I can't seem to find the place to set the GH project template in my On Demand solution. In the downloaded version I can set it from the tools > configuration dialog in the Planning Board but in On Demand, that option isn't there.
MinC
November 28, 2011
This is still the same in OnDemand solution. You need to go to Agile tab > Planning Board > Tools (appears on top right of the screen) > Configuration. If you didn't see the Configuration option, there is a possibility that you do not have 'Administer Project' permission in Permission Scheme.
Kasper Elbo November 28, 2011
The reason was lack of permissions, I just thought that the build-in administrator user would have all permissions on all projects.
Justin Mullen
November 27, 2011
I am also having this problem. Doesnt make sense. Someone else must have experienced this also.
