First off, sorry for the vague title.
I created a new custom greenhopper rank field "Request Rank"
It's been configured to show for issues in my Project, for any issue type. It's been added to every screen that issues in that project use.
I created a Custom Project Template and enabled my new custom field ("Request Rank") as the Ranking Field.
When I go to edit an existing issue and select the pencil next to the "None" value for the Request Rank field, it displays a Context dropdown (On the Fly or Default) and regardless of what I select, this message: "NO ISSUES TO DISPLAY"
When I go to Agile > Planning Board > Project Overview (and either Default or On the Fly) there are no issues displayed.
Any thoughts?
Thanks Dieter, this seems to be helping immensely. I see two issues in there now... and have not re-indexed yet. I did run Optimise (repair) after enabling "Fix Version".
When I try to add a rank on an existing ticket, I see this
When I create a new issue, it appears to be assigned a rank (the "7", represents the number of issues that have been created since I implemented the Rank field, there are hundreds of others in this Project)
Have you used the optimise/repair option for the ranking field?
