Groovy Script doesn't work JIRA 7
Sam Morris
Since upgrading to JIRA 7 my script on Scriptrunner to update a check box is no longer working.
The script finds the checkbox with it's existing values and adds a new value.
def checkbox_cf = customFieldManager.getCustomFieldObjects(parent).find {it.name == 'BI Deployed to Environment'}
def new_value = ComponentAccessor.optionsManager.getOptions(fieldConfig)?.find { it.toString() == 'UAT' }
def current_options = parent.getCustomFieldValue(checkbox_cf);
checkbox_cf.updateValue(null,parent,new
 ModifiedValue(parent.getCustomFieldValue(checkbox_cf),
current_options + [new_value]),changeHolder);
The error is occurring on
current_options + [uat_value]
Can anyone help?
Sam Morris
Thanks guys the answers is -
arno schumacher
Try
def customFieldManager = ComponentAccessor.customFieldManager
or
Hung Nguyen
I believe the customFieldManager must be gotten by a function instead
def customFieldManager = ComponentManager.getInstance().getCustomFieldManager()
Sam Morris
I declare the customfieldManager like this -
def MutableIssue parent = (MutableIssue) issue.getParentObject();
ComponentManager componentManager = ComponentManager.getInstance();
def customFieldManager = ComponentAccessor.CustomFieldManager
def optionsManager = ComponentManager.getComponentInstanceOfType(OptionsManager.class)
def changeHolder = new DefaultIssueChangeHolder();
Sam Morris
I'm getting this error in the logs -
groovy.lang.MissingPropertyException: No such property: CustomFieldManager for class: com.atlassian.jira.component.ComponentAccessor
Possible solutions: customFieldManager
Chander Inguva
February 12, 2016
Hi Sam,
              Did you turn on debugging and check what log file says ?
