Groovy help!!
Sanu Soman
March 18, 2014
Hi All,
I'm trying to upadte slect list custom field while creating an issue - Using below script for this,
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.customfields.manager.OptionsManager
def componentManager = ComponentManager.instance
def optionsManager = ComponentManager.getComponentInstanceOfType(OptionsManager.class)
def customFieldManager = componentManager.getCustomFieldManager()
def cf = customFieldManager.getCustomFieldObjectByName("Blocking status")
def fieldConfig = cf.getRelevantConfig(issue)
def option = optionsManager.getOptions(fieldConfig).find {it.value == "Blocked"}
issue.setCustomFieldValue(cf, option)
This code is working in all other places except at creating an issue (eventhough I placed this script in last in order).
Is something I need to change in code for making this works at create issue wrokflow transition?
Sanu P Soman
Tsol
March 18, 2014
Have a look here. You have to add cf.updateValue. More details on the link.
Sanu Soman
March 18, 2014
It works with,
issueManager.updateIssue(authenticationContext.getLoggedInUser(),issue,EventDispatchOption.DO_NOT_DISPATCH,true);
Many thanks for the help.
Boris Georgiev [Appfire]
March 18, 2014
The issue might not still exist when you're executing the code, so that's why it may not return proper value for the option.
Add some trace in the script to see what does the fieldConfig and option vars are not null. If they are null then check if the issue has project and issue type field set, as if they're not set fieldConfig will be alwas null
March 18, 2014
Kostas answer seems more precise... so check it first :)
