Groovy post script clone with customfields to description
Kevin Lynch March 15, 2013
I need to make the description containing a UserPicker custom field 10436 'Reports To' value and DatePicker custom field 10434 'Start Date' value. The current values in the ticket are 'Test User' which corresponds to username 'tuser' and '15/Mar/13'
issue.description = 'Reports To=' + cfValues['Reports To'] + '\nStart Date=' + cfValues['Start Date']
Output shows null in the description:
Reports To=null
Start Date=null
I want the output to be
Reports To=tuser
Start Date=15/Mar/13
Kevin Lynch March 26, 2013
okay, found the answer in the response to https://answers.atlassian.com/questions/70050/why-do-i-get-a-null-pointer-exception-when-try-to-execute-a-post-function
The field that you want to take with you from the original issue is not also available to the cloned issue/project, the value will be null. You must make the fields available to both projects and issues of the original and clone issue. You DO NOT have to place the field on any screens.
Therefore, the following worked just fine, and the values where passed to the cloned ticket and placed (overwrote) the Descriptions field.
issue.summary = issue.summary + ' (separation ticket from HR)'
issue.assigneeId = 'sysadmin'
JamieA
March 16, 2013
What context is this... some kind of post-function?
What happens if the user has entered a description, do you want to just overwrite it?
Kevin Lynch March 17, 2013
Yes, it is a post-function and yes, I want the description over written with the Reports To and Start Date information.
Kevin Lynch March 19, 2013
I also tried the below, but am getting:
javax.script.ScriptException: javax.script.ScriptException: java.lang.NullPointerException
import com.atlassian.jira.ComponentManager
def componentManager = ComponentManager.instance
def customFieldManager = componentManager.getCustomFieldManager()
def rt = customFieldManager.getCustomFieldObjectByName('Reports To')
def sd = customFieldManager.getCustomFieldObjectByName('Start Date')
issue.description = 'Report To=' + issue.getCustomFieldValue(rt) +'\nStart Date=' + issue.getCustomFieldValue(sd)
JamieA
March 19, 2013
Add some logging so you can see what exactly is null... could be one of the custom fields for instance/
Kevin Lynch March 22, 2013
Sorry, what package name should I log for?
Kevin Lynch March 24, 2013
Which package should I add to logging? thanks
JamieA
March 25, 2013
You can just add some log.warn() statements. You will add the logging statements to your code, rather than turn logging on from some other package.
Log Continued...
Caused by: java.lang.NullPointerException
at com.atlassian.jira.issue.customfields.impl.DateCFType.getDefaultValue(DateCFType.java:128)
at com.atlassian.jira.issue.customfields.impl.DateCFType.getDefaultValue(DateCFType.java:51)
at com.atlassian.jira.issue.fields.CustomFieldImpl.getDefaultValue(CustomFieldImpl.java:1124)
at com.atlassian.jira.issue.IssueImpl.getCustomFieldValue(IssueImpl.java:942)
at com.atlassian.jira.issue.Issue$getCustomFieldValue.call(Unknown Source)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at Script25.run(Script25.groovy:10)
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:315)
... 207 more
Okay, I've moved a little farther. But still can't figure out how to pull the original issue value. I ran the below in Script Runner and it pulls the values correctly from the Issue.
import com.atlassian.jira.issue.CustomFieldManager
CustomFieldManager customFieldManager = ComponentManager.getInstance().getCustomFieldManager()
issueOld = ComponentManager.getInstance().getIssueManager().getIssueObject("HR-823")
def cf = customFieldManager.getCustomFieldObject(10434)
def sd = issueOld.getCustomFieldValue(cf)
System.out.println(sd)
I modified my post function so I could hopefully see the output of the value in the logs, but it still has an problem.
def cf1 = customFieldManager.getCustomFieldObject(10436)
def cf2 = customFieldManager.getCustomFieldObject(10434)
rt = issue.getCustomFieldValue(cf1)
sd = issue.getCustomFieldValue(cf2)
System.out.println('Reports To=' + rt)
System.out.println('Start Date=' + sd)
My next comment will contain the log data
Part 1 of log
2013-03-26 11:40:13,699 http-apr-8080-exec-20 ERROR klynch 700x6222x1 1oxtgcn 10.1.74.16 /secure/CommentAssignIssue.jspa [onresolve.jira.groovy.GroovyFunctionPlugin] Error executing post-function
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:117)
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:233)
at javax.script.ScriptEngine$eval.call(Unknown Source)
at com.onresolve.jira.groovy.canned.utils.ConditionUtils.doAdditional(ConditionUtils.groovy:102)
at sun.reflect.GeneratedMethodAccessor2147.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90)
at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:233)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1001)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:1770)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
Caused by: javax.script.ScriptException: java.lang.NullPointerException
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:318)
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:111)
... 206 more
JamieA
March 26, 2013
Your println statements have gone to a different log... can you change the println to log.warn, and look for that output in the log.
I put the following, but catalina.out shows the same thing as before.
log.warn('Reports To=' + rt)
log.warn('Start Date=' + sd)
changed to:
log.warn(rt)
log.warn(sd)
The log is 227 lines and 21410 characters, so I can't post it. But it's the same output as what I posted in the two posts above.
