I need to make the description containing a UserPicker custom field 10436 'Reports To' value and DatePicker custom field 10434 'Start Date' value. The current values in the ticket are 'Test User' which corresponds to username 'tuser' and '15/Mar/13'
issue.description = 'Reports To=' + cfValues['Reports To'] + '\nStart Date=' + cfValues['Start Date']
Output shows null in the description:
Reports To=null
Start Date=null
I want the output to be
Reports To=tuser
Start Date=15/Mar/13
okay, found the answer in the response to https://answers.atlassian.com/questions/70050/why-do-i-get-a-null-pointer-exception-when-try-to-execute-a-post-function
The field that you want to take with you from the original issue is not also available to the cloned issue/project, the value will be null. You must make the fields available to both projects and issues of the original and clone issue. You DO NOT have to place the field on any screens.
Therefore, the following worked just fine, and the values where passed to the cloned ticket and placed (overwrote) the Descriptions field.
issue.summary = issue.summary + ' (separation ticket from HR)' issue.description = 'Reports To=' + cfValues['Reports To'] + '\nStart Date=' + cfValues['Start Date'] issue.assigneeId = 'sysadmin'
What context is this... some kind of post-function?
What happens if the user has entered a description, do you want to just overwrite it?
Yes, it is a post-function and yes, I want the description over written with the Reports To and Start Date information.
I also tried the below, but am getting:
javax.script.ScriptException: javax.script.ScriptException: java.lang.NullPointerException
import com.atlassian.jira.ComponentManager def componentManager = ComponentManager.instance def customFieldManager = componentManager.getCustomFieldManager() def rt = customFieldManager.getCustomFieldObjectByName('Reports To') def sd = customFieldManager.getCustomFieldObjectByName('Start Date') issue.description = 'Report To=' + issue.getCustomFieldValue(rt) +'\nStart Date=' + issue.getCustomFieldValue(sd)
Add some logging so you can see what exactly is null... could be one of the custom fields for instance/
You can just add some log.warn() statements. You will add the logging statements to your code, rather than turn logging on from some other package.
Log Continued...
Caused by: java.lang.NullPointerException at com.atlassian.jira.issue.customfields.impl.DateCFType.getDefaultValue(DateCFType.java:128) at com.atlassian.jira.issue.customfields.impl.DateCFType.getDefaultValue(DateCFType.java:51) at com.atlassian.jira.issue.fields.CustomFieldImpl.getDefaultValue(CustomFieldImpl.java:1124) at com.atlassian.jira.issue.IssueImpl.getCustomFieldValue(IssueImpl.java:942) at com.atlassian.jira.issue.Issue$getCustomFieldValue.call(Unknown Source) at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116) at Script25.run(Script25.groovy:10) at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:315) ... 207 more
Okay, I've moved a little farther. But still can't figure out how to pull the original issue value. I ran the below in Script Runner and it pulls the values correctly from the Issue.
import com.atlassian.jira.ComponentManager import com.atlassian.jira.issue.CustomFieldManager import com.atlassian.jira.issue.fields.CustomField CustomFieldManager customFieldManager = ComponentManager.getInstance().getCustomFieldManager() issueOld = ComponentManager.getInstance().getIssueManager().getIssueObject("HR-823") def cf = customFieldManager.getCustomFieldObject(10434) def sd = issueOld.getCustomFieldValue(cf) System.out.println(sd)
I modified my post function so I could hopefully see the output of the value in the logs, but it still has an problem.
import com.atlassian.jira.ComponentManager def componentManager = ComponentManager.instance def customFieldManager = componentManager.getCustomFieldManager() def cf1 = customFieldManager.getCustomFieldObject(10436) def cf2 = customFieldManager.getCustomFieldObject(10434) rt = issue.getCustomFieldValue(cf1) sd = issue.getCustomFieldValue(cf2) issue.summary = issue.summary + ' (separation ticket from HR)' System.out.println('Reports To=' + rt) System.out.println('Start Date=' + sd) issue.assigneeId = 'sysadmin'
My next comment will contain the log data
Part 1 of log
2013-03-26 11:40:13,699 http-apr-8080-exec-20 ERROR klynch 700x6222x1 1oxtgcn 10.1.74.16 /secure/CommentAssignIssue.jspa [onresolve.jira.groovy.GroovyFunctionPlugin] Error executing post-function javax.script.ScriptException: javax.script.ScriptException: java.lang.NullPointerException at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:117) at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:233) at javax.script.ScriptEngine$eval.call(Unknown Source) at com.onresolve.jira.groovy.canned.utils.ConditionUtils.doAdditional(ConditionUtils.groovy:102) at sun.reflect.GeneratedMethodAccessor2147.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:601) at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90) at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:233) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1001) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585) at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:1770) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603) at java.lang.Thread.run(Thread.java:722) Caused by: javax.script.ScriptException: java.lang.NullPointerException at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:318) at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:111) ... 206 more
Your println statements have gone to a different log... can you change the println to log.warn, and look for that output in the log.
I put the following, but catalina.out shows the same thing as before.
import com.atlassian.jira.ComponentManager def componentManager = ComponentManager.instance def customFieldManager = componentManager.getCustomFieldManager() def cf1 = customFieldManager.getCustomFieldObject(10436) def cf2 = customFieldManager.getCustomFieldObject(10434) rt = issue.getCustomFieldValue(cf1) sd = issue.getCustomFieldValue(cf2) issue.summary = issue.summary + ' (separation ticket from HR)' log.warn('Reports To=' + rt) log.warn('Start Date=' + sd) issue.assigneeId = 'sysadmin'
changed to:
import com.atlassian.jira.ComponentManager def componentManager = ComponentManager.instance def customFieldManager = componentManager.getCustomFieldManager() def cf1 = customFieldManager.getCustomFieldObject(10436) def cf2 = customFieldManager.getCustomFieldObject(10434) rt = issue.getCustomFieldValue(cf1) sd = issue.getCustomFieldValue(cf2) issue.summary = issue.summary + ' (separation ticket from HR)' log.warn(rt) log.warn(sd) issue.assigneeId = 'sysadmin'
The log is 227 lines and 21410 characters, so I can't post it. But it's the same output as what I posted in the two posts above.
