Groovy script for adding a project context to a custom field
Anshu Raina July 13, 2020
I want to add/create  a project context for a custom field using a groovy script.
Any help on this!
Vineela Durbha
Hi I am looking on adding projects to the customfield context. any help on this ?
Alex Koxaras _Relational_
Hi @Anshu Raina
Can you please be a bit more specific? You mean to edit the default's field context and update it so as to include certain projects? Or to create a new one?
Are you indeed on cloud, or on premises?
If you are on cloud, you could do that by using REST API and to be more specific this;
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-custom-field-contexts/#api-rest-api-3-field-fieldid-context-get
and you can choose either update or create.
