Groovy script to create or update jira issue using rest api
Ankita Sharma
I need to write a groovy script in post function to create or update a jira issue using rest api
Please Help.
Ankita Sharma
Thanos, the script worked fine but when used in post function, it did not create any issue sad. Rather, i got error as "groovyx.net.http.HttpResponseException: Bad Request".
Can you please let me know if i need to do something else also, in order to create issues in this way?
Thanos Batagiannis [Adaptavist]
January 14, 2016
Ankita, The link Vasiliy posted is really informative. You said it doesn't work for you ? Do you get any errors in your logs ?
Nic Brough -Adaptavist-
January 14, 2016
But why? When you're running a script, you have access to your JIRA. It's far faster, easier, flexible and more efficient to create them in the script.
Ankita Sharma
yes right, I have access to JIRA but want to create issues within JIRA using REST API (REST APIs available for JIRA; https://developer.atlassian.com/jiradev/jira-apis/jira-rest-apis/jira-rest-api-tutorials/jira-rest-api-example-create-issue) within a post function with groovy script. Later i will use REST API of some other applications.
January 12, 2016
I think Thanos is questioning the requirement. You already have direct access to the JIRA that your post-function is running in and do not need to use REST to talk to it. My guess is that you are writing code that updates another remote JIRA?
Ankita Sharma
Thanos, i have to use rest api only. Please suggest me. Vasiliy, i have already checked this link. The code is not working for me within post function. Would it be possible for you to provide me with a very basic code?
January 12, 2016
Ankita, is there a particular reason you want to use the rest api ?
Vasiliy Zverev
January 12, 2016
Ankita Sharma
Vasiliy, I am new to this code but on using it, I am unable to resolve HTTPContext. Even though I am using correct import statements, but it is not working for me :(
atlassian, jira product discovery, product operations, product ops, linkedin live, atlassian events, cross-functional collaboration, product management, engineering collaboration, design collaboration, atlassian learning, agile teams, product strategy
Product Ops Unpacked: 4️⃣ tips every product pro needs to know ✍️
Join PM Evangelist, Axel Sooriah, & Product Ops. Consultant & Advisor, Jenny Wanger, as they unpack the role of product ops and discuss key takeaways in Atlassian’s ‘The Product Ops Mission’ guide. They’ll answer your questions live on May 6 at 9:00am PT.
Register here ⬇️
