HELP ME! How to call Qmetry API by Postman
Hao Bui June 18, 2019
I try to get session by call to API "http://mygroup.atlassian.net/rest/auth/1/session" but the response is "You are not authenticated. Authentication required to perform this operation.". If I don't have the session, I can not call Qmetry for Jira API  https://qmetrysupport.atlassian.net/wiki/spaces/QOA20/pages/489652358/How+to+test+QMetry+Open+REST+API
I cannot access to Qmetry for Jira API. Could you please help me? Thanks.
Sahashraanshu June 18, 2019
Hello Bui,
I have reviewed your shared screenshots and I believe that you are using the incorrect URL in your Postman URL space in the place of "http://mygroup.atlassian.net/rest/auth/1/session".
Also, QMetry Open API is not supported for Jira Cloud. If you have further queries related to QMetry, you can reach out to QMetry Support through QMetry Support portal.
Sahashraanshu
Other step, I try input Authorization data, The response without error, but not found SESSIONID in there.
