HTTP error code from server: 500 when using JIRA issue macro
Jack Warner February 28, 2013
When trying to use the JIRA issue macro, I get the error message: HTTP error code from server: 500. Please check the log file for more information.
Please see attached.
Jack Warner March 11, 2013
We had a long thread in OnDemand support on this issue. Ultimately it was resolved, but the last thread was: "I removed the macro and inserted it again, now the macro is correctly working"
The other important part I was missing was that the link had to be copied from XML by selecting "XML" on "Views" menu.
https://support.atlassian.com/browse/JST-57951
Roman Samorodov
November 16, 2016
Turn on the oauth authentication in both JIRA and Confluence.
In JIRA go to Application Links click Edit -> Outgoing Authentication -> Oauth and click Enable.
The same steps for Incoming Authentication in JIRA.
Also you should do the same in Confluence.
Dave Theodore [Coyote Creek Consulting]
Did you get this figured out? If not, check that your application link between Jira and Confluence actually works. It can be tricky to get them set up sometimes.
