¿How can I associate automatically the same jira and harvest project without selecting it manually?
Hello Irene,
Thank you reaching out with this inquiry about your Harvest/JIRA integration. Can you clarify which tools you are using for this integration? Are you using on of the Harvest plugins from our Marketplace, or are you using a third-party integration tool? Furthermore, where are you wanting to automate the project selection? Can you provide a set of steps that show what you are currently doing manually to make this work?
~Andrew
