Once an Issue is created in a 'To Do Bucket' the issue stays on the screen for approximately 10 seconds and then disappears.
The Issue can only be found by using the global search feature. It will show the issue is in the correct register, but when you search the register it does not show any results.
Has anyone else had this happen and how do I correct this.
Hi @Santina Smith , welcome to the Community!
Would you be able to share the filter query your board uses? You'll need to be a board/project administrator to do so.
Likely, the issue does not match the query in some way - e.g. your board is set to show only Stories and you have created a Task.
Hi Michael,
I do not believe there is any filter on my board. Nothing has changed, the issues just not disappear.
I have put below a screenshot, is that what you were wanting to see?
