Health check problem after upgrade
Boris February 28, 2017
My colleague upgraded our Jira and Confluence from v7.1.8 to 7.3.1.
Now we have the following problem during our Health check:
"Checks if JIRA is able to access itself through the configured Base URL."
We have this configured in /etc/httpd/conf.d/ssl.conf:
<VirtualHost *:443>
    ServerAdmin networking@worldsupport.info
    ServerName jira.corp.int
    SSLEngine On
    SSLCertificateFile /etc/httpd/certs/jira.corp.int.crt
    SSLCertificateKeyFile /etc/httpd/certs/jira.corp.int.key
    SSLProxyEngine on
    ProxyPass / http://localhost:8080/ connectiontimeout=1200 timeout=1200
    ProxyPassReverse / http://localhost:8080/
    ProxyPreserveHost On
    ProxyTimeout 1200
    ProxyRequests Off
    ProxyVia Off
    ErrorLog /var/log/httpd/jira.corp.int/ssl-error.log
    LogLevel warn
    CustomLog /var/log/httpd/jira.corp.int/ssl-access.log combined
    ServerSignature On
    RequestHeader unset Proxy early
    </VirtualHost>
Also, we have Connector configured in our cat /opt/atlassian/jira/conf/server.xml:
<Connector port="8080"
    maxThreads="150"
    minSpareThreads="25"
    connectionTimeout="20000"
    enableLookups="false"
    maxHttpHeaderSize="8192"
    protocol="HTTP/1.1"
    useBodyEncodingForURI="true"
    redirectPort="8443"
    acceptCount="100"
    disableUploadTimeout="true"
    bindOnInit="false"
    ProxyName="jira.corp.int"
At this point the integration between Jira and Confluence is OK, but the Health check is not.
If we add to the connector those lines:
scheme="https"
    proxyName="jira.corp.int"
    proxyPort="443"
the integration between Jira and Confluence breaks down, but the Health check of Jira is OK.
Do you have any idea what seems to be the root cause of the problem?
Niclas Sandstroem
March 5, 2017
Without knowing the full story of your configuration or setup. But I would guess you run JIRA and Confluence on the same server without context path. If you can run JIRA and Confluence app links without proxy this should be possible by following this KB.
https://confluence.atlassian.com/kb/how-to-bypass-a-reverse-proxy-or-ssl-in-application-links-719095724.html
Please review the existing https://confluence.atlassian.com/jirakb/health-check-jira-base-url-859447384.html suggestions.
