Help: Can not deleted our organization. please help
hr
June 6, 2025
We can not delete our organization.
Delete button is disable. and found this error "This feature is unavailable for your organization. To transfer your apps to another organization, contact support and raise a ticket under the category Technical issues and bugs"
please help,
HR
Florian Bonniec
Hi @hr
You need to follow this KB
Delete your organization | Atlassian Support
If it do not work or face any error you should raise a request to Atlassian support.
Atlassian Support
Regards
FREE
