Help - Dashboard wallboard so dark its unreadable?
Callan Hough
January 25, 2021
We've tried numerous times to use jira's dashboard functionality but always hit some kind of blocker.
The main one is - when you 'view as wallboard' it sets a dark background, yes, but more than that, it seems to default set the brightness to -1000 lumens.... I'm only slightly exaggerating, it really is illegible.
Has anyone else encountered this issue, and is there a solution for it?
Gorka Puente _Appfire_
@Callan Hough,
I can only think of using a browser plugin to change the CSS, or if you're using a theming app like Refined for Jira, ask them if there's something it can be done.
On the other side, we develop a paid app called Ronin Dashboards for Jira, which has, IMO, a much better dark mode :) but you can always use the light mode when using the wallboard mode:
Hope this helps!
