Help EazyBy Import
moises neveu January 20, 2015
Good afternoon,
I tried to import the subtasks of a parent in particular, but I could not get it.
I used these JQL in Jira work, but not in EazyBi.
project = PROJECT and issueFunction in subtasksOf("issuetype = 'Bug'")
project = PROJECT and issueFunction in linkedIssuesOf("issuetype = 'Bug'")
issueFunction in linkedIssuesOf("project = PROJECT and issuetype = 'Bug'", "jira_subtask_link")
(issueFunction in subtasksOf("issuetype =\"Bug\"") AND project = "PROJECT")
Grateful aid you.
Best regards, thank you very much.
Thank you very much!
I'm trying to get a task type and all his daughters to import the cube, rather than after, will there be some other way to get to JQL? I could not even find a solution.
I am very grateful in advance for the help.
Peter Bengov
January 20, 2015
issueFunction is not standard JQL. It comes with Script Runner add-on. I believe that under Measures dimension you'll be able to find similar functions
