EazyBI: Measure to count issues that are created and due/expiring in the same month.
Marc Lim
July 5, 2019
Hi, I'm new to mdx language and eazybi in general. I would like to filter my issues across a time period of 12 months. The issues displayed per month should only be those that are created in that month and due for expiry in the same month. E. G for the month of Feb I would want to see all issues created this month, which have a due date in the month of Feb.
Would appreciate some help on this as I'm not sure where to start. Thanks in advance for advices/pointers!
Roberts Čāčus - eazyBI
September 11, 2019
Hi @Marc Lim ,
To create the report you are looking for, try to put the Time dimension on rows with "Month" level selected. To get the count of issues, try to create a new calculated member in the Measures dimensions, please have a look a the formula below:
Sum(
Filter(
Descendants([Issue].CurrentMember,[Issue].[Issue]),
DateInPeriod(
[Measures].[Issue created date],
[Time].CurrentHierarchyMember
AND
DateInPeriod(
[Measures].[Issue due date],
), [Measures].[Issues created]
The report could look similar to the one below:
Kind regards
Roberts // eazyBI support
Marc Lim
September 13, 2019
Thank you kindly for the reply. The answer worked.
Sekhar Chandra
Hi Marc
You can use JQL query for what type of issues you want to get into a list. Write a JQL in Issue Navigator window, search bar .
I provide a sample example query for your reference. I hope this would help you.
Please replace the dates as you require.
"created >= 2019-07-01 AND created <= 2019-07-31 AND due >= 2019-7-1 AND due <= 2019-7-31 order by created DESC"
Chandra
