I cannot figure out how to add a filter to my Plan to limit issues from the past. Please advise if there's a way to indicate a rolling date to only show issues from the prior 6 months.
Hey Emily,
You should be able to filter within a specific date range and can even save this as a custom view. You can also filter by specific releases if that helps.
Is this what you are looking for?
Thanks, no this is not working for me. I need to reduce the amount of issues (we are almost at max amount) that are showing up in the Plan overall. I feel like I should be able to do that from the screen shown below, in the release date column, but there is no filter anywhere in settings for this.
