Hi Team,
I have one file in my C drive, when Issue has been created in Project ABC, the file should be attach automatically.
I am using below code but not working as I expected.
import com.atlassian.jira.issue.IssueFieldConstants
import com.atlassian.jira.issue.attachment.TemporaryWebAttachment
import com.atlassian.jira.issue.attachment.TemporaryWebAttachmentManager
import webwork.action.ActionContext
def attachmentManager = ComponentAccessor.getAttachmentManager()
def user = ComponentAccessor.getJiraAuthenticationContext()?.getUser()
def bean = new CreateAttachmentParamsBean.Builder()
.file(new File("C:/Applications/Capgemini.jpg"))
.filename("Capgemini.jpg")
.contentType("image/png")
.author(user)
.issue(issue)
.build()
attachmentManager.createAttachment(bean)
Hi Musku
If you create a Scriptrunner "Custom script post-function" on the "Create" workflow transition and set the following script as the Last item on the list of POST functions it will allow you to add an attachment to issues on creation.
Script Link:
Add attachment from the Jira servers file system to the issue on creation
Note: You need to alter the script to fit the file path and name for your system.
Check the atlassian-jira.log if you have problems just in case you get permission errors.
Your original script was missing this line:
.copySourceFile(true)
which means it would work once and then the file would be deleted so all other attempts would fail.
Further information on the CreateAttachmentParamsBean class here.
Regards
Matthew
Hi
I have written the same code but it is showing error (No such file or directory)
Could you please check this. what's wrong i am doing ?
import com.atlassian.jira.issue.attachment.CreateAttachmentParamsBean
def user = ComponentAccessor.getJiraAuthenticationContext()?.loggedInUser
String pathToFile = "C:/Users/kbharadwaj/Downloads/"
String fileName = "Testing.txt"
String pathAndFile = pathToFile+fileName
.file(new File(pathAndFile))
.filename(fileName)
.contentType("text/txt")
.author(user)
.issue(issue)
.copySourceFile(true)//you must do this otherwise it deletes the source file from the file system
.build()
Hi @kanishka , please fine my code here bitbucket.org/nagarajureddy
let me know if you need any.
Nagaraju
@Musku Nagaraju Thanks for reply.
I have tried this code many times. but every time it shows error(No such file or directory).
I have placed file in same place.
Hello @Matthew Clark
Thank you - your code works great for a JSD request created.
I have one dumb query - can you please provide any suggestions on how to download the automatically attached file to a local system on a simple mouse click, once the request is created.
I am asking this, because if the JSD customer clicks on the attachment, they get an encrypted file in the same window, something like the one shown in the attached screenshot.
Hello @shira segal inbar
Nothing so far. I am trying ways to get this resolved.
The only workaround to this is to right-click on the attachment, and use the "Save As..." option.
Rahul
Hi @Rahul Savaikar I found the solution :-)
You need to change one of the lines in the code to -
.contentType("plain/txt")That helped me
Shira
Hello @shira segal inbar ,
Wow, thanks - this worked.
Perhaps, you can move this as an answer, and I can upvote.
Best Regards,
Rahul Savaikar
Perfect, that is exactly what I was looking for and it works like a charm. In fact had to spent more time to get the file upon the server than to get this post function added to the workflow.
Hi Masku
Can you tell me more about your requirement?
Are you trying to attach the same image to every new issue created or does the attachment change?
Is it always an image?
Is your Jira server running on windows and you want to pull in the file from within the Jira server itself or is this C drive on the client machine?
@Matthew Clark ,I am trying to attach same one file in all issues that will never change.
It always file (.doc)
I am trying to pull this from client C drive, also I am fine this to pull from JIRA server as well, Help me on easy way.
Nagaraju
