Help needed for JQL
Ankit Mahajan April 2, 2021
 For the below scenario - I am trying to come up with JQL but not able to. Tried "IssueFunction" etc or referring Script Runner https://scriptrunner.adaptavist.com/latest/jira/jql-functions.html#_epicsof. If anyone has any inputs for the below scenario, can you please share?
Show me all the Stories that have a Pcode “A” AND Epic Link of stories is not with Pcode “A” or with Component Value “B”
Note- Pcode and Component are Fields in both Stories and Epics
Kate Kabir
April 4, 2021
Hi @Ankit Mahajan
I can confirm that if you are using ScriptRunner for Jira Cloud, it does support issuesInEpics() JQL function documentation page under Enhanced Search Included Functions located here. You may kindly refer to the documentation on how to configure the JQL.
I hope this helps
Kate
Ste Wright
Hi @Ankit Mahajan
In terms of Scriptrunner, make sure you're following the instructions for Cloud not Server, as these do differ.
From what I understand above, you want to see:
  • All Stories with Pcode "A"...
  • That are children of Epics which...
  • Do not have a Pcode of "A" OR...
  • Have a component of "B"
If yes, something along these lines should work...
issueFunction in issuesInEpics("component = B OR Pcode != A") AND issuetype = Story AND Pcode = A
This is how it works:
  • The function issuesInEpics will show all children of any Epic which satisfies the subquery.
  • The subquery in the brackets searches against all Epics, based on the relevant search parameters.
  • The and Pcode = A refines the results based on the parameters referring to Story-level
You might need to change this slightly based on field name or field type (for the operators), but this should work!
Ste
