×We are OnDemand client. We want to limit the selection for FixVersion field to one option only, however, we didnt found an option for this. We decided to hide the FixVersion field and to create a custom field called Fixed Version, which is using the versions entries, but allows a single selection.
Once we did this - our BurnDown charts stopped working and based on the information i have found, they incrementally rely on this FixVersion field.
How can we fix this situation?
Hi Kamen,
I think you can't because Versions (= FixVersions) can have a hierarchy with the GreenHopper Plugin. For example Version a can have children, such as a-sprint-1, a-sprint-2, a-sprint-3, ...
If an issue is part of a child version, the fixed version field shows the child version and the parent version also.
I don't know, if you can change the base of the burndown charts, but I don't think so.
Hope, this makes things a little bit clearer, although it's no solution for your problem...
Cheers
Thomas
Not in OnDemand. Otherwise you had a couple of options:
http://www.j-tricks.com/1/post/2011/12/one-fixversion-please.html
https://studio.plugins.atlassian.com/wiki/display/GRV/Validators
yes, i have found those options, but not applicable for onDemand. :)
another question - i guess we will have to go back and live with the multiple selection of the original fixVersion field, in order to have all statistics displayed properly. since we have already filled out a lot of issues with our custom version field, is it possible to merge the date from the two fields and to start working afterwords only with the original fixVersion one?
thanks in advance,
Kamen
Yes, that is possible. Download the CLI and use copy field option (I believe it is possible)
https://bobswift.atlassian.net/wiki/display/JCLI/JIRA+Command+Line+Interface
any clues how i have to do it? i guess i should use copyFieldValue syntaxis, but what should be the command to update all issues in all projects? :)
It can be ask small as a simple shell script like:
cli with options to save issues to a file a.txt from a project using the jql for i in `a.txt` do cli again using copyField with $i as the issue id done
And you have to the manuals, Bob has put in efforts to make it with examples ;)
