Help with JQL query - quotation marks
Louise Pancholi
August 5, 2021
Hello, I'm trying to search for subtasks of issues with certain criteria. The criteria I want to search for contain custom fields with spaces, so I need to use quotation marks, however JIRA interprets this as finishing the 'subtasksOf' statement. Is there a different way I can write the query, without using a plugin?
Example:
issueFunction in subtasksOf("project = PRJ AND issuetype = Story AND status not in (Closed) AND component in ("Salesforce Service Cloud")")
3 votes
Deniz Tımartaş
Hi there,
Try this:
issueFunction in subtasksOf("project = PRJ AND issuetype = Story AND status not in (Closed) AND component in (\"Salesforce Service Cloud\")")
So you should use \" to escape that character.
Best Regards.
Pedro Felgueiras
August 5, 2021
I agree with @Deniz Tımartaş but you could also reference filters inside filters
Create a first filter with project = PRJ AND issuetype = Story AND status not in (Closed) AND component in ("Salesforce Service Cloud") and check the ID on the URL
Ater that create a second filter issueFunction in subtasksOf("filter = 123123"). Replace 123123 with the ID of the previus filter.
If the filter get's more complex it's simpler to use this way.
Like Deniz Tımartaş likes this
Louise Pancholi
August 9, 2021
That worked! Thanks a lot both!
