Help with JQL query
Mélanie Liguet
I search a workitem that contains the key to another workitem in his summary field.
This JQL query does not return any results
However, I have a issuethat exists with "depro-686" in his summary.
Can you help me with my JQL query ?
regards
3 accepted
4 votes
John Funk
Hi Mélanie,
Just try Project = ABC and summary ~ "DEPRO-686"
Mélanie Liguet
same
Marc - Devoteam
September 11, 2025
Hi @Mélanie Liguet
Try project = iss and summary ~ "DEPRO-686*"
This as the Summary states DEPRO-686-TEST
Marc - Devoteam
September 11, 2025
Hi @Mélanie Liguet
I just tried this,Test API-2
Using the search options:
  1. summary ~ API-2
  2. summary ~ "API-2"
Both JQL options found the issue
Matteo Vecchiato
September 11, 2025
Hi @Mélanie Liguet ,
Thank you for your question.
If you are searching for DEPRO-686 it is just required to write the following jql:
summary ~ "DEPRO-686" (without \")
If you are searching for "DEPRO-686":
summary ~ "\"DEPRO-686\""
If you are searching for [DEPRO]:
summary ~ "\\[DEPRO\\]"
 Hope it helps
Mélanie Liguet
but, thats  not works without \"
Matteo Vecchiato
September 11, 2025
I replicated the same work item and jql and for me it works:
Try to debug the jql removing piece by piece
Like Mélanie Liguet likes this
Mélanie Liguet
I found
a dash had slipped behind xxx-686-
If I remove the dash, it works.
Thank you very much for your help.
Marc - Devoteam
September 11, 2025
Hi @Mélanie Liguet
Please accept the community members answers as a solution, if the answers helped to solve or provide a workaround to your request.
This will help other community member trying to solve the same or provide them with a work around
Like Tim Kopperud likes this
