Help with Scriptrunner - Parent issue not transitioning when sub-task transitions
Alex Cumberland
March 2, 2021
ScriptRunner 6.18.0
Jira Server 8.13.1
The logs show no issues and displays the values that I expect but the parent stays in the "Open" status.
The sub-task and parents use the same workflow.  The transition that I am trying for the parent is "Start Progress" (transition id = 4) which would put it in status "In Progress" (step id = 3) from "Open" or "Reopened" status.
I am using the following script that is the last step in the post-functions:
import com.atlassian.jira.bc.issue.IssueService;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.user.ApplicationUser;
import com.atlassian.jira.workflow.TransitionOptions;
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.project.Project;
// Logging Imports
import org.apache.log4j.Level
import org.apache.log4j.Logger
log = Logger.getLogger("console")
log.setLevel(Level.DEBUG)
def Project project = issue.getProjectObject()
Integer actionID = 4; // Transition ID value
log.debug "project key: " + project.key;
log.debug "issue key: " + issue.key;
log.debug "issue Type: " + issue.issueType.name;
// Only want to perform for sub-tasks in the OK Project
if (project.key == "OK" && issue.issueType.name == "Sub-task") {
IssueService issueService = ComponentAccessor.getIssueService();
// Get the userID that is logged in currently
ApplicationUser currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser();
// Get the parent issue object
MutableIssue parent = issue.getParentObject() as MutableIssue
// Check the status of the parent object
def isValidSubTaskStatus = parent.status?.name in ['Open', 'Reopened']
// If the parent status is valid, then we want to transition the parent
if (isValidSubTaskStatus) {
TransitionOptions transitionOptions = new TransitionOptions.Builder()
.skipConditions()
.skipPermissions()
.skipValidators()
.build()
IssueService.TransitionValidationResult result = issueService.validateTransition(currentUser,
parent.getId(),
actionID,
issueService.newIssueInputParameters(),
transitionOptions)
Alex Cumberland
March 2, 2021
Figured out the issue and was a real self head smack moment.
The script is fine except it does not have a step to do the actual transition.
Needs the following Code after the Validate Transition step:
if (result.isValid()) {
issueService.transition(currentUser, result);
Doing this will then actually fire the transition on the parent.
SERVER
VERSION
8.13.1
