Hi I have found a script that I want to make work in a Script Runner Custom field to display the full name not the username, which I then can use in the Jira macro in Confluence. My lack of groovy knowledge has me stuck on the 'token' error shown in snip .
Full script below:
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.fields.CustomField import com.atlassian.jira.user.ApplicationUserCustomField field = ComponentAccessor.customFieldManager.getCustomFieldObjectsByName("Owner")[0] // if there is no value for this field, exit the script if (!issue.getCustomFieldValue(field)) returnreturn (issue.getCustomFieldValue(field) as ApplicationUser).displayName
Thanks in advance
Cheers
Gordon
Hi Gordon
You see that error mainly due to a typo where your field declaration is on the same line as your import. Also, it appears there are a few other typos because you are missing some curly braces and the return statements are incorrect.
Finally, there is also the problem of trying to return a string (the display name) while using the `User Picker` script field Template, which expects you to return the ApplicationUser object.
If you want to return a string representing the user's `Display Name` you can use the `Text Field (multi-line)` script field template and a script like this:
def field = ComponentAccessor.customFieldManager.getCustomFieldObjects().find {
it.name == "Owner"
assert field
def value = issue.getCustomFieldValue(field)
// if there is no value for this field, return null
value ? (value as ApplicationUser).displayName : null
I hope this helps.
Regards
Matthew
