Help with planning versions in JIRA
Neal Culiner
February 12, 2014
We LOVE JIRA! One area we struggle with is planning future versions. We use the agile tools and use sprints, and presently we load the "Fixed Version(s)" field to put the version an issue is "planned" for as well as fixed for when the issue is resolved. As the owner/stakeholder, I'm not thrilled with using the "Fixed Version" field as I'd rather that just be used for resolving an issue.
We really would love to have a GUI that we can drag cards as an example to different lanes that represent different versions. I've researched and it seems that Atlassian recommends the sprints as the tool for this, that would be okay IF we could have multiple sprints horizontally (vertical list) above the backlog. Then we can drag issues right/left across versions for better planning.
Does anyone know of an add-on or a system that would help us do more visual planning of versions instead of using the Fixed Version(s) field?
Thank you.
Andy Nguyen
February 13, 2014
Hi Neal,
If I'm not mistaken, what you want is already available in Plan mode of Scrum board. You can create multiple sprints above the backlog (click Create Sprint) and drag issues to different versions for planning purpose. Notice that the Fix Version/s field of an issue will be updated after you drop it to a corresponding version:
Andy
Neal Culiner
February 14, 2014
Thanks Andy - I'm familiar with that for sprint planning, it's not the greatest layout. I'd prefer the versions to be across the top in lanes just like when in a sprint and you have the three columns to drag issues across. It would be a nice planning board to have selected versions at the top in vertical lanes, each version next to each other in columns, backlog below, then you can place issues in desired versions for release planning.
Andy Nguyen
February 14, 2014
Hi Neal,
I think I understand your desire now. However, we currently do not have that layout and I don't think some plugin will do. I know each team would have its desired way of planning tasks but, to some extent, the current layout is really doing its work. Highly appreciate your understanding.
All the best,
Andy
Martin Connolly
June 14, 2016
I have exactly the same need and am shocked that JIRA or an add-on does not have a viable option for this.
I regard that screenshot as the worst, most unhelpful  screen in JIRA
Tarun Sapra
You can try http://www.tempoplugin.com/products/tempo-planner/
workin' only with JIRA 6.x onwards
Neal Culiner
February 12, 2014
We use JIRA's latest at all times. We do have tempo planner installed but it's for resource (people) planning AFAIK and not for project/version planning such as placing issues to versions.
