Hello
I am trying to write jira cloud addon. I have setup environment and could see basic hello world app following https://developer.atlassian.com/cloud/confluence/getting-set-up-with-ace/
The addOn that I need to write takes 2 inputs
I need to display in a table no.of issues each user has per release
I have experience writing Jira reports, but cloud I am looking for some sample which could help me do this.
Any pointers is appreciated.
Abraham
Hello @AbrahamA ,
I understand you would like to build a Jira Cloud add-on, however the documentation you are following is for Confluence Cloud.
If my understanding is correct then you may want to follow the below documentation instead:
Please review above page and then, depending on what you have chosen to build your app with, you have the links to specific documentation pages and tutorials on the left hand side menu. For example:
INTRODUCTION AND BASICS
Or:
LEARNING
Also, for the future, please notice that this is not the best place to get help on development related questions. The right resources are listed in https://developer.atlassian.com/resources.
Specifically:
Dario
