×I need to link my jira projects with MS Project. Is it possible?
You can use Ceptah Bridge: https://www.ceptah.com. It can synchronise most JIRA fields as well as Tempo. It has been around for 10+ years and caters for most real-life scenarios.
for a rather specialized App like this one it will be unlikely you will meet somebody here in Community just in the moment you need a thorough answer - that would be of a great coincidence.
If your ask would have been to a very common App with thousands of customers it would be a different story.
Basically you are left with two common options:
Daniel
Hi Daniel thanks for the suggestion. appreciate it.
No this is not possible at least based on my experience and understanding. What exactly is your goal here?
I need to extract Jira Projects to MS Projects to create some project level dashboards with additional columns.
There are couple of plugins when i search in google. But dont know whether it works or not
