×The idea is to post a script via API in a specific Script listener in ScriptRunner is that possible?
I think the best way to do this is to post the script to the Script Register via API.
If you open your network console and upload a file to the register you will find the API used.
Then you can keep your script in a repo and create a pipeline to upload it. Then you can create your custom Listener in Scriptrunner to point to the file.
Bibby-ty-bibby-ty-bop
