I would like to know if there is a pre-defined config or settings within Jira that would help me with integration of Envo8 (Environment Management Tool) or if there is any specific support guide or documentation that can help me guide with instructions how to integrate with an external tool.
Also, would like to know if there is any sort of limitation integrating with any external tools.
Thank you
Rajiv
Hi @rajiv.radha
Thanks for your question.
Have you tried using our Golive Jira App for Test Environment Management in Jira?
Once you have defined your environments in Jira/Golive, you can synchronize them with other TEM tools like Enov8. As soon as your environments are synchronized, you can use them in your Jira issues and Jira dashboards (there are 3 Golive Gadgets available).
Feel free to contact me if you need further assistance with this integration.
Have a nice day,
David
That's not a tool I've heard of, so all I can tell you is that you've five options (which can work together if you find some of them do only parts of whatever "integration" you want to do)
