Hi, how to write nested if in serverside script and check whther value is greater than specific valu
Yatam_ Annapurna November 2, 2017
Question 1: How to write nested if (If filed1 equal to "Ready for WOC" and field3 equal to Provider SSCR", then Field2 should be mandatory)
def field1 = getFieldByName("Current Status")
def field2 = getFieldByName("SSCR #")
def field3 = getFieldByName("Type")
if(field1.getValue().equals("Ready for WOC") ) // tried "AND", "&&", "&" but didn't work
  if(field3.getValue().equals("Provider SSCR"))
{ field2.setRequired(true) }
else { field2.setRequired(false) }
Question 2: How to check if the value is greater than a specific value (If filed1 equal to "Ready for WOC" and field3 greater than 44.52, then Field2 should be mandatory)
def field2 = getFieldByName("Justification for High Blended Rate")
def field3 = getFieldByName("Actual Blended Rate")
if(field3.getValue().equals("44.52")) // not able to understand how to say greater than
Question 3:
How to say "not equal to". I tried "!=" didn't work.
I am trying to say field1 not equal to empty. and field1 is string.
Thanks in advance for your help!
Praveen November 10, 2017
Hi Anna,
For Q1: Try this
if((field1.getValue().equals("Ready for WOC"))&&(field3.getValue().equals("Provider SSCR"))){}
Hi Anna
For Q3: Try this
if (field1 != null){}
