While sending slack notifications for a specified channel can i tag user , i mean the member is
To be precise i need to send notification to channel in that i need to mention user that activity belongs to him
I can see rule overwriding only can i mention user as a tag for that channel notication
Welcome to the Community!
Have you check out the Docs?
Refer - https://support.atlassian.com/cloud-automation/docs/use-automation-with-slack/
Send messages to a user - In the Channel or user field, enter @MemberID (e.g.: @U123) to send your message to a specific user. Note that this isn't the same as someone's display name. You can find their member ID by opening someone's profile in Slack and selecting More (…) > Copy member ID.
i checked the docs, is it possible on the channel to mentioned @[deleted]
to notify them that it is their, people present in channel
For example
my channel name is event-reminder - a private
Hi Team, need to check health of prod @username or @userid
to notify that is their activity
