×Buen día comunidad alguien tendrá el body de creación de un proyecto en Jira pero formato JSON?
Agradezco su apoyo
Hi @[deleted]
Please take a look at the REST API for creating a project to see if that helps you:
https://docs.atlassian.com/software/jira/docs/api/REST/1000.824.0/#api/2/project-createProject
Best regards,
Muchas gracias por la información a servido de mucho, quería preguntarte si tu sabes como dentro de JSON se puede llamar a un campo especifico para obtener su valor ?
Hi @[deleted]
I suggest starting with the Get Issues call to see if that returns what you need. Many of the issue fields are included by that single call.
https://docs.atlassian.com/software/jira/docs/api/REST/1000.824.0/#api/2/issue-getIssue
There are other specific calls for things like entity properties and attachments, so look at those calls for other ideas.
