Since beta of OnDemand Version the keyboard-shortcut "t" won't work. All other shortcuts are working. It is really annoying, because if you use it every day, it is an automatism.
The t shortcut for logging work is specific to the Tempo plugin:
http://blog.tempoplugin.com/2013/tempo-tip-of-the-month-keyboard-shortcuts/
Are you using Tempo in your OnDemand instance?
Gary
