Using the Tempo plugin I ran into the issue of trying to log more than 100 hours a time.
"Hours worked must be less than 100"
Is it possible to increase this limit?
Devs sometimes only input work hours when resolving the issue and their total work time could be over 100 hours.
Yes it is possible. See Max hours per day per user
I'm currently using the "Unlimited" default value and I still get the 100 hours limit error.
Thanks for letting us know. We will have a look.
I'm getting the same problem - also have Unlimited selected but can't enter more than 100 hours.
Same here. It is set to unlimited but the error still shows up.
I still encounter this error - what is the timeframe for the fix, the issue is more than a year old..
