Hours worked must be less than 100
Patrick Bureau January 27, 2013
Using the Tempo plugin I ran into the issue of trying to log more than 100 hours a time.
"Hours worked must be less than 100"
Is it possible to increase this limit?
Devs sometimes only input work hours when resolving the issue and their total work time could be over 100 hours.
Viðar Svansson [Tempo]
January 27, 2013
Yes it is possible. See Max hours per day per user
I'm currently using the "Unlimited" default value and I still get the 100 hours limit error.
January 28, 2013
Thanks for letting us know. We will have a look.
Maya S Chase
July 22, 2014
I'm getting the same problem - also have Unlimited selected but can't enter more than 100 hours.
Roman Baranov
same here. Doesn't let me set over 100 hours.
Ivaylo Stanev
Same here. It is set to unlimited but the error still shows up.
Mads Frost
I still encounter this error - what is the timeframe for the fix, the issue is more than a year old..
Mads Frost
Christian Vorraber February 5, 2014
Is this issue already fixed?
