How Can I Add scope for Specific Project
Vitheya Monikha June 13, 2025
Hi ,
How can I set scope for a specific project? In case you haven't seen the code snippets, I've sent them again. Please take a look at them
UI Code
 const onSubmit = async (data=> {
      var bodyData;
      setIsLoading(true)
      const folderExists = tree.some(folder => folder.value === data.folderName || folder.value === `${data.folderName}(${parentFolderName})`);
      if (folderExists) {
         setIsLoading(false)
         setFlagTitle('Failure!');
         setFlagMessage('Error: Folder name already exists');
         addFlag();
         return;
      console.log("ParentfoldernameID.........."projectId)
      if (parentFolderName === 'Test Repository') {
         bodyData = {
            fieldId: testCaseFieldId,
            projectKey: projectKey,
            projectId: projectId
         console.log("bodyDataID.........."projectId)
      else {
         console.log("else.........."projectId)
         bodyData = {
         console.log("projectid.........."projectId)
      console.log("Data..."bodyData)
      try {
         const response = await invoke('addOptionToCustomField'bodyData); // API call to get projects
         console.log("comp Response...."response)
         if (response.options[0].id) {
            setIsLoading(false)
            setFlagTitle("Success!")
            setFlagMessage('Folder created successfully')
            setIsOpen(false)
            setShowParentDrp(false);
            reset();
            addFlag();
            setTree([])
            setFolderLoader(true)
            getUpdatedComponentList()
      } catch (error) {
         setIsLoading(false)
         setFlagMessage(`Error while creating folder${error}`)
         addFlag();
         return [];
Backend Code
resolver.define("addOptionToCustomField"async({payload}) => {
  console.log("addOptionToCustomField")
  const { fieldIdnameprojectKey } = payload
  console.log("projectkey.........",projectKey)
  try{
    console.log("Payload to create options..."fieldId)
    const contextResponse = await api.asApp().requestJira(route`/rest/api/3/field/${fieldId}/context`, {
      method: "GET",
      headers: { "Accept": "application/json" },
    const contextData = await contextResponse.json();
    console.log("contextData......"contextData)
    const targetContext  = contextData.values.find(ctx => ctx.name === projectKey);
    const optionData = [{ value: name }];
    console.log("Option Data........"optionData)
    var res = await api.asApp().requestJira(route`/rest/api/3/field/${fieldId}/context/${targetContext}/option`, {
        method: "POST",
        headers: {
            "Accept": "application/json",
            "Content-Type": "application/json",
        body: JSON.stringify({options: optionData}),
      const data = await res.json()
      console.log(`✅ Dropdown options added for ${fieldId}!...`data);
      return data
  catch(error){
    return {"code": 2000"message": "Error while creating folder"}
Vitheya Monikha June 18, 2025
As per your suggestion, I have changed the code, but the project ID is not available in the context data. I would like to know how to add my project ID to it. I have also added the context data JSON as below.
Could you please let me know how to add projectID to the context data JSON?
This is the backend code
resolver.define("addOptionToCustomField", async ({ payload }) => {
  const { fieldId, name, projectId } = payload
  console.log("projectkey.........", projectId)
  try {
    console.log("Payload to create options...", fieldId)
      method: "GET",
    console.log("contextData......", contextData)
  console.log("payload.projectId.........", projectId)
      ctx.projectIds && ctx.projectIds.includes(projectId)
    console.log("targetContext........", targetContext)
    console.log("Option Data........", optionData)
    var res = await api.asApp().requestJira(route`/rest/api/3/field/${fieldId}/context/${targetContext.id}/option`, {
      method: "POST",
      headers: {
      body: JSON.stringify({ options: optionData }),
    console.log(`✅ Dropdown options added for ${fieldId}!...`, data);
    return data
  catch (error) {
    return { "code": 2000, "message": "Error while creating folder" }
Example log
contextData...... {
maxResults: 50,
startAt: 0,
total: 1,
isLast: true,
values: [
name: 'Default Configuration Scheme for Folders',
description: 'Default configuration scheme generated by Jira',
isGlobalContext: true,
isAnyIssueType: true
Tuncay Senturk _Snapbytes_
Hi @Vitheya Monikha
I am not sure if I get your question right but here are my two cents on this.
To set the scope of a custom field to a specific project using your Forge backend function, you need to create (or find if there is) field context that is scoped to the project, and then add the option to that context.
you are using the above code to find but it is IMO incorrect as the project name may not be equal to the projectKey. The below would be a better approach
ctx.projectIds && ctx.projectIds.includes(payload.projectId)
Please console log to see what data it has and correct the code accordingly.
Also you need to update the rest (targetContext -> targetContext.id) as the below. targetContext is an object not the ID itself.
if no such content exists (targetContext is undefined) you'll need to create a new field context scoped to the project.
POST /rest/api/3/field/${fieldId}/context
Then use the new context ID to post the options.
I hope that helps
