I'm trying to set up an automation that allows a JIRA task to automatically notify an assignee's teammate/manager when created.
I've received this instruction from the community:
However, I can't seem to find the Project Settings button. I'm currently a user access admin.
Hi @Lea S
welcome to atlassian community
To access project settings you need to be project administrator of the respective project.
only project admins can see the project settings button which is why it’s not available to you. Get in touch with your jira admin/ existing admins to provide you the access.
Let me know if this helps.
Hi @Lea S
Welcome to the community :)
This means you don't have the admin access to your project you are trying to see automation
Please reach out to your admin and ask them to give you below permission in the project
Please refer to this for more information : https://support.atlassian.com/cloud-automation/docs/permissions-required-for-jira-cloud-automation-rules/
and https://support.atlassian.com/cloud-automation/docs/create-and-configure-jira-automation-rules/ for more details
If this helps, please accept the answer
Thank YOu,
Prachi
